[mapguide-users] MapGuide Maestro 6.0m13 and mapguide-react-layout 0.14.10 released
Jackie Ng
jumpinjackie at gmail.com
Tue Feb 18 00:41:22 PST 2025
Please fully expand all the properties on the logged MapGuide/INIT_ERROR
action, especially the error property and screenshot that
- Jackie
On Tue, 18 Feb 2025 at 18:33, Nimrod Cnaan <nimcnaan at gmail.com> wrote:
> [image: image.png]
> בתאריך שבת, 15 בפבר׳ 2025 ב-3:11 מאת Jackie Ng via mapguide-users <
> mapguide-users at lists.osgeo.org>:
>> This is not helpful. I do not see any relation between the
>> unexpected token `<` and this error.
>> The mapInit property is an AJAX viewer API property that custom task pane
>> content can test to see if the map viewer is ready to start using their
>> other APIs. This error suggests that you must have a custom InvokeURL
>> command that has some javascript that calls this property without testing
>> that the call chain is already not null/undefined (ie.
>> Caling parent.parent.mapInit without testing that parent.parent is not
>> null/undefined first)
>> Again I am just speculating because I have not been given enough
>> information to work with.
>> Can you switch over to use viewer-debug.js (instead of viewer.js) and
>> provide screenshots of the viewer and relevant parts of the developer tools
>> where the error is happening?
>> - Jackie
>> You wrote:
>> this is the Error we get - Uncaught TypeError: Cannot read properties of
>> undefined (reading 'mapInit')
>> at About:486:42
>> mapguide-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
> בכבוד רב,
> *נמרוד כנען** | *גיאומינד שירותי GIS – פיתוח, ייעוץ ושירותי ענן
> ישיר: 048101268 | נייד: 0525355483 | nimrod at geomind.co.il
> נא בקרו באתר החדש שלנו http://geomind.co.il
http://themapguyde.blogspot.com
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250218/c88f3e34/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20250218/c88f3e34/attachment.png>
