[mapguide-users] MGOS 4 Beta 2 and CodeIgniter
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Tue Jan 20 08:39:58 PST 2026
The code, found here:
https://themapguyde.blogspot.com/2022/04/mapguide-dev-diary-important.html?m=1
You can put the PHP in the C:\Program Files\OSGeo\MapGuide\Web\www\
folder..
gordon
On Tue, Jan 20, 2026 at 11:04 AM David Bowen <dbowenrci at gmail.com> wrote:
> Where are the functions called in Jackie's "sanity check" code located?
> I'm presuming the PHP extension file MapGuideApi.dll file but would like
> confirmation. I'm trying to get help through the CodeIgniter forums but
> need to have a better understanding of what's being called.
> On Mon, Jan 12, 2026 at 8:27 AM David Bowen <dbowenrci at gmail.com> wrote:
>> Hi Gordon,
>> Unfortunately, adding that line to httpd.conf didn't resolve the issue.
>> I'm still getting the same error.
>> On Fri, Jan 9, 2026 at 10:25 AM Gordon Luckett <
>> gordon.luckett at arrowgeomatics.com> wrote:
>>> I wonder if you should add the following to your conf file?
>>> AddType application/octet-stream .agf
>>> On Fri, Jan 9, 2026 at 10:20 AM David Bowen <dbowenrci at gmail.com> wrote:
>>>> Hi Gordon,
>>>> Thanks for providing this, and apologies for the delayed response. I
>>>> added it to one of the application's controllers and wasn't able to get it
>>>> to successfully run. I'm able to get the initial section of code to echo to
>>>> screen, but once there are MapGuide functions, it fails.
>>>> This section of code works fine:
>>>> echo "Initializing web tier";
>>>> try {
>>>> MgInitializeWebTier("DIR_PATH\Web\www\webconfig.ini");\
>>>> } catch (MgException $initEx) {
>>>> echo "Init failure!";
>>>> die;
>>>> } catch (Exception $ex) {
>>>> echo "[php]: Exception: " . $ex->getMessage() . "\n";
>>>> die;
>>>> echo "[php]: Initialized\n";
>>>> // We haven't and shouldn't need to require/include constants.php
>>>> // they are now baked into the PHP extension along with the other
>>>> // MapGuide API proxy classes
>>>> echo "[php]: Testing some constants\n";
>>>> The next line is where it fails:
>>>> echo " - " . MgMimeType::Agf . "\n";
>>>> The error CodeIgniter's returning is:
>>>> Class "App\Controllers\Maptools\MgMimeType" not found
>>>> It seems like MapGuide functions aren't being recognized/loaded by
>>>> CodeIgniter. The MapGuideAPI is enabled in php.ini, and it shows as enabled
>>>> when I run info.php.
>>>> Any input would be greatly appreciated.
>>>> Thanks,
>>>> David
>>>> On Wed, Nov 12, 2025 at 11:05 AM Gordon Luckett <
>>>>> Hi David
>>>>> When in doubt, I use Jackie's Sanity Check..
>>>>> On Wed, 12 Nov 2025, 10:39 David Bowen via mapguide-users, <
>>>>> mapguide-users at lists.osgeo.org> wrote:
>>>>>> Our application is built using the Model/View/Controller (MVC)
>>>>>> framework CodeIgniter and I'm attempting to update the MVC framework from
>>>>>> v3.1.13 to v4.6.3, but I'm encountering an issue where it seems that one of
>>>>>> the MapGuide functions isn’t being loaded or recognized. The issue occurs
>>>>>> during the log out process, where a user logs out of the application and
>>>>>> there's a series of steps that take place to destroy the sessions (code
>>>>>> below).
>>>>>> I'm getting the following error when I attempt to log out of the
>>>>>> application: Call to undefined function
>>>>>> App\Controllers\Login\MgUserInformation(). This function,
>>>>>> MgUserInformation, is successfully called when the user first logs into the
>>>>>> application and a session is created, so I’m unclear what’s causing the
>>>>>> issue.
>>>>>> Does anyone have familiarity with MGOS and CodeIgniter 4, or would
>>>>>> anyone have suggestions on how to check if MGOS functions are being
>>>>>> properly loaded?
>>>>>> We're running MGOS 4 Beta 2 and are unable to go to MGOS 4 until
>>>>>> we've updated the MCV framework.
>>>>>> Thanks,
>>>>>> David
>>>>>> function logout() {
>>>>>> //Log out and destroy session
>>>>>> $this->mgExtDir = getenv('mg_extensionsDir');
>>>>>> $this->webconfig_ini = getenv( 'webconfigFilePath' );
>>>>>> $this->mgMapID = $this->_getValueByFieldName( 'MAPNAME' );
>>>>>> $this->mgSessionId = $this->_getValueByFieldName( 'SESSION' );
>>>>>> try {
>>>>>> // Initialize the Web Extensions and connect to the Server
>>>>>> using
>>>>>> // the Web Extensions session identifier stored in PHP
>>>>>> session state.
>>>>>> MgInitializeWebTier( $this->webconfig_ini );
>>>>>> $si = $this->mgSessionId;
>>>>>> // code fails on following line
>>>>>> $userInfo = new MgUserInformation( $this->mgSessionId );
>>>>>> $siteConnection = new MgSiteConnection();
>>>>>> $siteConnection->Open( $userInfo );
>>>>>> $siteConnection->GetSite()->DestroySession(
>>>>>> } catch ( MgException $e ) {
>>>>>> echo $e->GetMessage();
>>>>>> echo $e->GetDetails();
>>>>>> $session_dat = array( 'logged_in' => FALSE );
>>>>>> session()->set( $session_dat );
>>>>>> session()->destroy();
>>>>>> return redirect()->to( 'login/login' ); //Direct user back to
>>>>>> login screen
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260120/4101e292/attachment.htm>
