[mapguide-users] MGOS 4 Beta 2 and CodeIgniter
David Bowen
dbowenrci at gmail.com
Tue Jan 20 11:05:06 PST 2026
Hi Gordon,
Sorry, I don't think I properly explained what I'm looking for. When
Jackie's script is run, where are the functions it calls located? For
example, when MgMimeType is called, where is the corresponding code? Is it
located in the PHP extension MapGuideApi.dll? When I try to run the script
using CodeIgniter 4, I get an error message saying the Class can't be
located.
On Tue, Jan 20, 2026 at 11:40 AM Gordon Luckett <
gordon.luckett at arrowgeomatics.com> wrote:
> The code, found here:
> https://themapguyde.blogspot.com/2022/04/mapguide-dev-diary-important.html?m=1
> You can put the PHP in the C:\Program Files\OSGeo\MapGuide\Web\www\
> folder..
> gordon
> On Tue, Jan 20, 2026 at 11:04 AM David Bowen <dbowenrci at gmail.com> wrote:
>> Where are the functions called in Jackie's "sanity check" code located?
>> I'm presuming the PHP extension file MapGuideApi.dll file but would like
>> confirmation. I'm trying to get help through the CodeIgniter forums but
>> need to have a better understanding of what's being called.
>> On Mon, Jan 12, 2026 at 8:27 AM David Bowen <dbowenrci at gmail.com> wrote:
>>> Hi Gordon,
>>> Unfortunately, adding that line to httpd.conf didn't resolve the issue.
>>> I'm still getting the same error.
>>> On Fri, Jan 9, 2026 at 10:25 AM Gordon Luckett <
>>>> I wonder if you should add the following to your conf file?
>>>> AddType application/octet-stream .agf
>>>> On Fri, Jan 9, 2026 at 10:20 AM David Bowen <dbowenrci at gmail.com>
>>>> wrote:
>>>>> Hi Gordon,
>>>>> Thanks for providing this, and apologies for the delayed response. I
>>>>> added it to one of the application's controllers and wasn't able to get it
>>>>> to successfully run. I'm able to get the initial section of code to echo to
>>>>> screen, but once there are MapGuide functions, it fails.
>>>>> This section of code works fine:
>>>>> echo "Initializing web tier";
>>>>> try {
>>>>> MgInitializeWebTier("DIR_PATH\Web\www\webconfig.ini");\
>>>>> } catch (MgException $initEx) {
>>>>> echo "Init failure!";
>>>>> die;
>>>>> } catch (Exception $ex) {
>>>>> echo "[php]: Exception: " . $ex->getMessage() . "\n";
>>>>> die;
>>>>> echo "[php]: Initialized\n";
>>>>> // We haven't and shouldn't need to require/include constants.php
>>>>> // they are now baked into the PHP extension along with the other
>>>>> // MapGuide API proxy classes
>>>>> echo "[php]: Testing some constants\n";
>>>>> The next line is where it fails:
>>>>> echo " - " . MgMimeType::Agf . "\n";
>>>>> The error CodeIgniter's returning is:
>>>>> Class "App\Controllers\Maptools\MgMimeType" not found
>>>>> It seems like MapGuide functions aren't being recognized/loaded by
>>>>> CodeIgniter. The MapGuideAPI is enabled in php.ini, and it shows as enabled
>>>>> when I run info.php.
>>>>> Any input would be greatly appreciated.
>>>>> Thanks,
>>>>> David
>>>>> On Wed, Nov 12, 2025 at 11:05 AM Gordon Luckett <
>>>>>> Hi David
>>>>>> When in doubt, I use Jackie's Sanity Check..
>>>>>> On Wed, 12 Nov 2025, 10:39 David Bowen via mapguide-users, <
>>>>>> mapguide-users at lists.osgeo.org> wrote:
>>>>>>> Our application is built using the Model/View/Controller (MVC)
>>>>>>> framework CodeIgniter and I'm attempting to update the MVC framework from
>>>>>>> v3.1.13 to v4.6.3, but I'm encountering an issue where it seems that one of
>>>>>>> the MapGuide functions isn’t being loaded or recognized. The issue occurs
>>>>>>> during the log out process, where a user logs out of the application and
>>>>>>> there's a series of steps that take place to destroy the sessions (code
>>>>>>> below).
>>>>>>> I'm getting the following error when I attempt to log out of the
>>>>>>> application: Call to undefined function
>>>>>>> App\Controllers\Login\MgUserInformation(). This function,
>>>>>>> MgUserInformation, is successfully called when the user first logs into the
>>>>>>> application and a session is created, so I’m unclear what’s causing the
>>>>>>> issue.
>>>>>>> Does anyone have familiarity with MGOS and CodeIgniter 4, or would
>>>>>>> anyone have suggestions on how to check if MGOS functions are being
>>>>>>> properly loaded?
>>>>>>> We're running MGOS 4 Beta 2 and are unable to go to MGOS 4 until
>>>>>>> we've updated the MCV framework.
>>>>>>> Thanks,
>>>>>>> David
>>>>>>> function logout() {
>>>>>>> //Log out and destroy session
>>>>>>> $this->mgExtDir = getenv('mg_extensionsDir');
>>>>>>> $this->webconfig_ini = getenv( 'webconfigFilePath' );
>>>>>>> $this->mgMapID = $this->_getValueByFieldName( 'MAPNAME' );
>>>>>>> $this->mgSessionId = $this->_getValueByFieldName( 'SESSION' );
>>>>>>> try {
>>>>>>> // Initialize the Web Extensions and connect to the Server
>>>>>>> using
>>>>>>> // the Web Extensions session identifier stored in PHP
>>>>>>> session state.
>>>>>>> MgInitializeWebTier( $this->webconfig_ini );
>>>>>>> $si = $this->mgSessionId;
>>>>>>> // code fails on following line
>>>>>>> $userInfo = new MgUserInformation( $this->mgSessionId );
>>>>>>> $siteConnection = new MgSiteConnection();
>>>>>>> $siteConnection->Open( $userInfo );
>>>>>>> $siteConnection->GetSite()->DestroySession(
>>>>>>> } catch ( MgException $e ) {
>>>>>>> echo $e->GetMessage();
>>>>>>> echo $e->GetDetails();
>>>>>>> $session_dat = array( 'logged_in' => FALSE );
>>>>>>> session()->set( $session_dat );
>>>>>>> session()->destroy();
>>>>>>> return redirect()->to( 'login/login' ); //Direct user back to
>>>>>>> login screen
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260120/d9b564bc/attachment.htm>
