[mapguide-users] Widget Label Accentuation not working
pc.brutus.xyz at gmail.com pc.brutus.xyz at gmail.com
Mon Jul 13 09:56:15 PDT 2026
Was your XML file saved using UTF-8 encoding?
or
Have you try to replace ã with ã
(Visão to Visão)
Regards
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org> De la part de
Liglio Cavalcante via mapguide-users
Envoyé : 13 juillet 2026 10:16
À : mapguide-users at lists.osgeo.org
Cc : liglio.pessoal at nexxa.com.br
Objet : [mapguide-users] Widget Label Accentuation not working
I tried to use accentuation in a custom Widget at Label or Tooltip but is
not working, despite the encoding="utf-8" in XML.
Words like Visão are displayed Vis?o. Maybe the parser it is not applying
the right encoding. Can I correct this ?
Mapguide 3.1.2 – Fusion Viewer
Regards,
Liglio Cavalcante
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260713/da707d62/attachment.htm>
