[mapguide-users] RES: Widget Label Accentuation not working
liglio.pessoal at nexxa.com.br
Mon Jul 13 15:11:24 PDT 2026
Hi Pierre,
The widget is edited through Maestro at Web Layout Flexible. I suppose it is
saved in the library, then the Fusion Viewer parses this XML to create the
Widget.
I already tried to replace ã with ã same result. Maestro converts
ã to ã when the widget is saved. This is a parser problem in Fusion, or
some configuration to made.
Regards,
Liglio Cavalcante
De: pierre.cardinal at sympatico.ca <pierre.cardinal at sympatico.ca>
Enviada em: segunda-feira, 13 de julho de 2026 13:55
Para: 'MapGuide Users Mail List' <mapguide-users at lists.osgeo.org>
Cc: liglio.pessoal at nexxa.com.br
Assunto: RE: [mapguide-users] Widget Label Accentuation not working
Was your XML file saved using UTF-8 encoding?
or
Have you try to replace ã with ã
(Visão to Visão)
Regards
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org
<mailto:mapguide-users-bounces at lists.osgeo.org> > De la part de Liglio
Cavalcante via mapguide-users
Envoyé : 13 juillet 2026 10:16
À : mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
Cc : liglio.pessoal at nexxa.com.br <mailto:liglio.pessoal at nexxa.com.br>
Objet : [mapguide-users] Widget Label Accentuation not working
I tried to use accentuation in a custom Widget at Label or Tooltip but is
not working, despite the encoding="utf-8" in XML.
Words like Visão are displayed Vis?o. Maybe the parser it is not applying
the right encoding. Can I correct this ?
Mapguide 3.1.2 Fusion Viewer
Regards,
Liglio Cavalcante
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260713/accf544c/attachment.htm>
