[mapguide-users] RES: Widget Label Accentuation not working
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Mon Jul 13 15:32:53 PDT 2026
Could it be something like putting the META tag
<meta charset="UTF-8">
...in the index.html (or index.templ MGOS 4) to enforce the UTF-8?
On Mon, Jul 13, 2026 at 6:26 PM Liglio Cavalcante via mapguide-users <
mapguide-users at lists.osgeo.org> wrote:
> Hi Pierre,
> The widget is edited through Maestro at Web Layout Flexible. I suppose
> it is saved in the library, then the Fusion Viewer parses this XML to
> create the Widget.
> I already tried to replace ã with ã same result. Maestro converts
> ã to ã when the widget is saved. This is a parser problem in Fusion,
> or some configuration to made.
> Regards,
> Liglio Cavalcante
> *De:* pierre.cardinal at sympatico.ca <pierre.cardinal at sympatico.ca>
> *Enviada em:* segunda-feira, 13 de julho de 2026 13:55
> *Para:* 'MapGuide Users Mail List' <mapguide-users at lists.osgeo.org>
> *Cc:* liglio.pessoal at nexxa.com.br
> *Assunto:* RE: [mapguide-users] Widget Label Accentuation not working
> Hi,
> Was your XML file saved using UTF-8 encoding?
> or
> Have you try to replace ã with ã
> (Visão to Visão)
> Regards
> Pierre
> *De :* mapguide-users <mapguide-users-bounces at lists.osgeo.org> *De la
> part de* Liglio Cavalcante via mapguide-users
> *Envoyé :* 13 juillet 2026 10:16
> *À :* mapguide-users at lists.osgeo.org
> *Cc :* liglio.pessoal at nexxa.com.br
> *Objet :* [mapguide-users] Widget Label Accentuation not working
> Hi,
> I tried to use accentuation in a custom Widget at Label or Tooltip but is
> not working, despite the encoding="utf-8" in XML.
> Words like Visão are displayed Vis?o. Maybe the parser it is not applying
> the right encoding. Can I correct this ?
> Mapguide 3.1.2 – Fusion Viewer
> Regards,
> Liglio Cavalcante
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260713/a0712d73/attachment.htm>
