[mapguide-users] RES: RES: Widget Label Accentuation not working
liglio.pessoal at nexxa.com.br liglio.pessoal at nexxa.com.br
Tue Jul 14 08:11:51 PDT 2026
Hi Gordon,
I put <meta charset="UTF-8"> in both index files and it did not work.
Regards,
 Liglio Cavalcante
De: mapguide-users <mapguide-users-bounces at lists.osgeo.org> Em nome de Gordon Luckett via mapguide-users
Enviada em: segunda-feira, 13 de julho de 2026 19:33
Para: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Cc: Gordon Luckett <gordon.luckett at arrowgeomatics.com>
Assunto: Re: [mapguide-users] RES: Widget Label Accentuation not working
Could it be something like putting the META tag
...in the index.html (or index.templ MGOS 4) to enforce the UTF-8?
On Mon, Jul 13, 2026 at 6:26 PM Liglio Cavalcante via mapguide-users <mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org> > wrote:
Hi Pierre,
The widget is edited through Maestro at Web Layout Flexible. I suppose it is saved in the library, then the Fusion Viewer parses this XML to create the Widget.
I already tried to replace ã with ã same result. Maestro converts ã to ã when the widget is saved. This is a parser problem in Fusion, or some configuration to made.
Regards,
Liglio Cavalcante
De: pierre.cardinal at sympatico.ca <mailto:pierre.cardinal at sympatico.ca>  <pierre.cardinal at sympatico.ca <mailto:pierre.cardinal at sympatico.ca> >
Enviada em: segunda-feira, 13 de julho de 2026 13:55
Para: 'MapGuide Users Mail List' <mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org> >
Cc: liglio.pessoal at nexxa.com.br <mailto:liglio.pessoal at nexxa.com.br>
Assunto: RE: [mapguide-users] Widget Label Accentuation not working
Was your XML file saved using UTF-8 encoding?
or
Have you try to replace ã with ã
(Visão to Visão)
Regards
Pierre
De : mapguide-users <mapguide-users-bounces at lists.osgeo.org <mailto:mapguide-users-bounces at lists.osgeo.org> > De la part de Liglio Cavalcante via mapguide-users
Envoyé : 13 juillet 2026 10:16
À : mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
Cc : liglio.pessoal at nexxa.com.br <mailto:liglio.pessoal at nexxa.com.br>
Objet : [mapguide-users] Widget Label Accentuation not working
I tried to use accentuation in a custom Widget at Label or Tooltip but is not working, despite the encoding="utf-8" in XML.
Words like Visão are displayed Vis?o. Maybe the parser it is not applying the right encoding. Can I correct this ?
Mapguide 3.1.2 – Fusion Viewer
Regards,
Liglio Cavalcante
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260714/e3b21139/attachment.htm>
