[mapguide-users] RES: Modify the map definition and web layout flexible definition of a session
liglio.pessoal at nexxa.com.br liglio.pessoal at nexxa.com.br
Wed Jun 3 12:51:10 PDT 2026
Hi Gordon,
This is part of a code. I have Session and MapName and I can’t read the map object of a session.
public class UtilMap : IDisposable
    private string strSessionMap;
    private string strMapDefinition;
    private MgSiteConnection siteConnection;
    private MgUserInformation userInfo;
    private MgFeatureService featureService;
    private MgResourceService resourceService;
    private MgMap map;
    private string mapName;
    private string strTempLayerSufix;
    /// <summary>
    /// Constructor of class to manipulate the RunTime Mapguide Map
    /// </summary>
    /// <param name="pstrSessionMap">Map Session ID</param>
    /// <param name="pstrMapDefinition">Map Library Definition</param>
    public UtilMap(string pstrSessionMap, string pstrMapDefinition)
        try
            this.strSessionMap = pstrSessionMap;
            this.strMapDefinition = pstrMapDefinition;
            this.strTempLayerSufix = "-" + strSessionMap;
            this.siteConnection = new MgSiteConnection();
            this.userInfo = new MgUserInformation(this.strSessionMap);
            try
                this.siteConnection.Open(this.userInfo);
            catch (Exception ex)
                throw new Exception("Erro UtilMap SiteConnection Open: " + ex.Message);
            this.featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
            this.resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
            this.mapName = this.strMapDefinition;
            // if mapName is empty, I just want to work with session repository, no map session operations
            if (!string.IsNullOrEmpty(this.mapName))
                this.map = new MgMap(this.siteConnection);
                try
                    this.map.Open(this.resourceService, this.mapName);
                    throw new Exception("Error UtilMap Map Open: " + ex.Message);
            // Cleans internal references, if implemented correctly
            if (this.siteConnection != null){this.siteConnection.Dispose(); this.siteConnection = null;}
            if (this.userInfo != null){this.userInfo.Dispose(); this.userInfo = null;}
            if (this.featureService != null){this.featureService.Dispose(); this.featureService = null;}
            if (this.resourceService != null){this.resourceService.Dispose(); this.resourceService = null;}
            if (this.map != null){this.map.Dispose(); this.map = null;}
            throw new Exception("Error UtilMap criation: pstrSessionMap = " + pstrSessionMap + ", pstrMapDefinition = " + pstrMapDefinition + " :: Mensagem : "+ ex.Message);
    public void SetFusionViewerInitialView(string webLayoutDefinition, double dblX, double dblY, double dblScale)
                    MgResourceIdentifier resourceID = null;
                    MgByteReader reader = null;
                    string strXml = string.Empty;
                    try
                                // IT DOES NOT WORK
                        resourceID = this.map.GetMapDefinition();
                        reader = this.resourceService.GetResourceContent(resourceID);
                        strXml = reader.ToString();
                        // I CAN NOT FIND THE MAP OBJECT
                        //resourceID = new MgResourceIdentifier("Session:" + this.strSessionMap + "//" + this.mapName + "." + MgResourceType.MapDefinition);
                                resourceID = new MgResourceIdentifier("Session:" + this.strSessionMap + "//" + this.mapName + this.strTempLayerSufix + "." + MgResourceType.MapDefinition);
                        throw new Exception(System.Reflection.MethodInfo.GetCurrentMethod().Name + "::" + ex.Message);
                    finally
                        if (resourceID != null) { resourceID.Dispose(); resourceID = null; }
                        if (reader != null) { reader.Dispose(); reader = null; }
Regards,
Liglio Cavalcante
De: Gordon Luckett <gordon.luckett at arrowgeomatics.com>
Enviada em: quarta-feira, 3 de junho de 2026 15:26
Para: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Cc: liglio.pessoal at nexxa.com.br
Assunto: Re: [mapguide-users] Modify the map definition and web layout flexible definition of a session
If you have the Session and MapName you should be able to modify the map without needing the MgResourceIdenifier.
On Wed, Jun 3, 2026 at 2:06 PM Liglio Cavalcante via mapguide-users <mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org> > wrote:
Is it possible to read and modify the map definition and web layout flexible definition of a session ?
I tried serveral combinations of map names for the resource ID, with no success.
Example:: resourceID = new MgResourceIdentifier("Session:" + sessionId + "//" + "Mapa GIS - Fusion" + "." + MgResourceType.MapDefinition);
Regards,
Liglio Cavalcante
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260603/b84f6021/attachment.htm>
