[mapguide-users] Modify the map definition and web layout flexible definition of a session
Gordon Luckett
gordon.luckett at arrowgeomatics.com
Fri Jun 5 07:45:22 PDT 2026
Using PHP (sorry my default code)
I can get the MapDefinition (from a simple InvokeURL widget - note the
lower-case mapname and session)
<?php
$configFilePath = "C:\Program Files\OSGeo\MapGuide\Web\www\webconfig.ini";
$session = urldecode($_REQUEST["session"]);
$mapName = urldecode($_REQUEST["mapname"]);
MgInitializeWebTier($configFilePath);
$userInfo = new MgUserInformation($session);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$featureService = $siteConnection->CreateService(2);
$resourceService = $siteConnection->CreateService(0);
$map = new MgMap($siteConnection);
$map->Open($mapName);
$mapDef = $map->GetMapDefinition();
echo $mapDef->ToString();
$reader = $resourceService->GetResourceContent($mapDef);
echo $reader->ToString();
On Wed, Jun 3, 2026 at 3:51 PM <liglio.pessoal at nexxa.com.br> wrote:
> Hi Gordon,
> This is part of a code. I have Session and MapName and I can’t read the
> map object of a session.
> public class UtilMap : IDisposable
> private string strSessionMap;
> private string strMapDefinition;
> private MgSiteConnection siteConnection;
> private MgUserInformation userInfo;
> private MgFeatureService featureService;
> private MgResourceService resourceService;
> private MgMap map;
> private string mapName;
> private string strTempLayerSufix;
> /// <summary>
> /// Constructor of class to manipulate the RunTime Mapguide Map
> /// </summary>
> /// <param name="pstrSessionMap">Map Session ID</param>
> /// <param name="pstrMapDefinition">Map Library Definition</param>
> public UtilMap(string pstrSessionMap, string pstrMapDefinition)
> try
> this.strSessionMap = pstrSessionMap;
> this.strMapDefinition = pstrMapDefinition;
> this.strTempLayerSufix = "-" + strSessionMap;
> this.siteConnection = new MgSiteConnection();
> this.userInfo = new MgUserInformation(this.strSessionMap);
> try
> this.siteConnection.Open(this.userInfo);
> catch (Exception ex)
> throw new Exception("Erro UtilMap SiteConnection Open: " +
> ex.Message);
> this.featureService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
> this.resourceService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> this.mapName = this.strMapDefinition;
> // if mapName is empty, I just want to work with session
> repository, no map session operations
> if (!string.IsNullOrEmpty(this.mapName))
> this.map = new MgMap(this.siteConnection);
> try
> this.map.Open(this.resourceService, this.mapName);
> throw new Exception("Error UtilMap Map Open: " +
> ex.Message);
> // Cleans internal references, if implemented correctly
> if (this.siteConnection !=
> null){this.siteConnection.Dispose(); this.siteConnection = null;}
> if (this.userInfo != null){this.userInfo.Dispose();
> this.userInfo = null;}
> if (this.featureService !=
> null){this.featureService.Dispose(); this.featureService = null;}
> if (this.resourceService !=
> null){this.resourceService.Dispose(); this.resourceService = null;}
> if (this.map != null){this.map.Dispose(); this.map = null;}
> throw new Exception("Error UtilMap criation: pstrSessionMap =
> " + pstrSessionMap + ", pstrMapDefinition = " + pstrMapDefinition + " ::
> Mensagem : "+ ex.Message);
> public void SetFusionViewerInitialView(string webLayoutDefinition,
> double dblX, double dblY, double dblScale)
> MgResourceIdentifier resourceID = null;
> MgByteReader reader = null;
> string strXml = string.Empty;
> try
> // IT DOES NOT WORK
> resourceID = this.map.GetMapDefinition();
> reader =
> this.resourceService.GetResourceContent(resourceID);
> strXml = reader.ToString();
> // I CAN NOT FIND THE MAP OBJECT
> //resourceID = new MgResourceIdentifier("Session:"
> + this.strSessionMap + "//" + this.mapName + "." +
> MgResourceType.MapDefinition);
> resourceID = new
> MgResourceIdentifier("Session:" + this.strSessionMap + "//" + this.mapName
> + this.strTempLayerSufix + "." + MgResourceType.MapDefinition);
> reader =
> throw new
> Exception(System.Reflection.MethodInfo.GetCurrentMethod().Name + "::" +
> ex.Message);
> finally
> if (resourceID != null) { resourceID.Dispose();
> resourceID = null; }
> if (reader != null) { reader.Dispose(); reader =
> null; }
> Regards,
> Liglio Cavalcante
> *De:* Gordon Luckett <gordon.luckett at arrowgeomatics.com>
> *Enviada em:* quarta-feira, 3 de junho de 2026 15:26
> *Para:* MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> *Cc:* liglio.pessoal at nexxa.com.br
> *Assunto:* Re: [mapguide-users] Modify the map definition and web layout
> If you have the Session and MapName you should be able to modify the map
> without needing the MgResourceIdenifier.
> On Wed, Jun 3, 2026 at 2:06 PM Liglio Cavalcante via mapguide-users <
> mapguide-users at lists.osgeo.org> wrote:
> Hi,
> Is it possible to read and modify the map definition and web layout
> flexible definition of a session ?
> I tried serveral combinations of map names for the resource ID, with no
> success.
> Example:: resourceID = new MgResourceIdentifier("Session:" + sessionId +
> "//" + "Mapa GIS - Fusion" + "." + MgResourceType.MapDefinition);
> Regards,
> Liglio Cavalcante
> mapguide-users mailing list
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20260605/71110cb0/attachment.htm>
