[mapguide-dev] GetLocalizedString
Scott Hameister ScottH at mPower-tech.com
Wed Nov 15 20:01:07 EST 2006
Looking at the Last line of the Selected Code         "$unitsType =
GetLocalizedString("DISTANCEMETERS", $locale);"
What is happening here??? Im not a PHP programmer and I cant find a function
Called GetLocalizedString anywhere..
.What would this be in a Map with no Coordsys? Or is that Irrelevant?
//get the map extent and calculate the scale factor
        $mapExtent = $map->GetMapExtent();
        $srs = $map->GetMapSRS();
        if($srs != "")
            $csFactory = new MgCoordinateSystemFactory();
            $cs = $csFactory->Create($srs);
            $metersPerUnit = $cs->ConvertCoordinateSystemUnitsToMeters(1.0);
            $unitsType = $cs->GetUnits();
        else
            $metersPerUnit = 1.0;
            $unitsType = GetLocalizedString("DISTANCEMETERS", $locale);
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061115/126a0827/attachment.html
More information about the Mapguide_dev mailing list
