[mapguide-dev] GetLocalizedString
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Nov 15 20:37:08 EST 2006
It's a static helper method used to look up a localized string by name
(name="DISTANCEMETERS" in this case).  The source for the method (not
particularly interesting) is in the file PhpLocalizer.cpp in this
folder:
https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/Ph
pApi/
The localized strings are stored in resource files, and the locale
argument specifies which file to use.  In the open source vault the
resource files are located in this folder:
https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/lo
calized/.
Don't know offhand where the web tier install actually puts them - look
for a "localized" folder.
The vault only contains the English resource file, named "en".  Using
that locale, the returned string in this example would be "Meters".  The
coordinate system doesn't come into play.
Walt
  _____
From: Scott Hameister [mailto:ScottH at mPower-tech.com]
Sent: Thursday, November 16, 2006 2:01 AM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] GetLocalizedString
Looking at the Last line of the Selected Code         "$unitsType =
GetLocalizedString("DISTANCEMETERS", $locale);"
What is happening here??? Im not a PHP programmer and I cant find a
function Called GetLocalizedString anywhere....
...What would this be in a Map with no Coordsys? Or is that Irrelevant?
//get the map extent and calculate the scale factor
        $mapExtent = $map->GetMapExtent();
        $srs = $map->GetMapSRS();
        if($srs != "")
            $csFactory = new MgCoordinateSystemFactory();
            $cs = $csFactory->Create($srs);
            $metersPerUnit =
$cs->ConvertCoordinateSystemUnitsToMeters(1.0);
            $unitsType = $cs->GetUnits();
        else
            $metersPerUnit = 1.0;
            $unitsType = GetLocalizedString("DISTANCEMETERS", $locale);
URL: http://lists.osgeo.org/pipermail/mapguide_dev/attachments/20061115/6cae56aa/attachment.html
More information about the Mapguide_dev mailing list
