[mapguide][MG180][Modified] Rename DigitizePolyline API to DigitizeLineString
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Apr 4 01:28:55 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG180
Type:
Defect
Artifact ID:
MG180 (Rename DigitizePolyline API to DigitizeLineString)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
x
New value:
The current digitize API uses DigitizePolyline.
-- Description set to new value:
Old value:
With MapGuide we want to use the term LineString instead of Polyline.
New value:
With MapGuide we want to use the term LineString everywhere instead of Polyline. The Geometry API, for example, uses LineString.
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Developer Notes set to new value:
This will be a change to the public 1.0.0 API. Do we need to deprecate the old API?
-- Summary changed:
Old value:
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
