[mapguide][MG179][Modified] TCP/IP Connection Pooling for Web Extensions and Server
Trevor Wekel trevor.wekel at autodesk.com
Tue Apr 4 12:02:52 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG179
Type:
Enhancement
Artifact ID:
MG179 (TCP/IP Connection Pooling for Web Extensions and Server)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
Implemement additional code changes and fixups to enable TCP/IP connection pooling between the Web Extensions and the Server.  This is common infrastructure submission that affects all long running processes:
- MapGuide Site Server
- MapGuide Support Servers
- FastCGI MapAgent
- Web Extensions for .Net
- Web Extensions for Java
The Web Extensions for Php are not currently configured as a long running process.  The Php Web Extensions will use connection pooling during the lifetime of php-cgi.exe but Php as a FastCGI should be configured in a later submission to reap the full benefit of connection pooling.
New value:
- FastCGI MapAgent
Testing Performed:
Server/Windows: OK (379 Tests)
Web Tier/Windows: 986/986 passed
Sheboygan Sample app is functional:
Php and .Net tested on Windows
Php and Java tested on Linux
Admin functional on both platforms
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
