[mapguide][MG184][New] Fix nonlocalized string in buffer UI
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Apr 4 12:28:18 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG184
Type
 Defect
Artifact ID
 MG184 (Fix nonlocalized string in buffer UI)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Priority set to new value
  P2
- Target milestone set to new value
  1.0.1
- Operating system set to new value
  All
- Summary set to new value
- Version set to new value
  1.0.0
- Description set to new value
  The buffer UI uses a hard-coded string "Buffer 1" in one place.  This needs to be moved into the resource file for localization.
- Defect Severity set to new value
  High
- Steps to Reproduce set to new value
  x
- Artifact created
- Platform set to new value
  All
- Artifact Status set to new value
  New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
