[mapguide][MG191][Modified] Layer filter is ignored for DWF-based layers
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Fri Apr  7 11:15:15 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG191
Type:
Defect
Artifact ID:
MG191 (Layer filter is ignored for DWF-based layers)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Review Comments set to new value:
The filter processing code needs to do more than just wcsstr.  If the layer filter is set to "layer1" and your DWF contains a layer called "layer" then the check incorrectly passes.  It needs to split the filter into tokens and compare the layer against each token using something like wcscmp.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
