[mapguide][MG191][Modified] Layer filter is ignored for DWF-based layers
Traian Stanev
traian.stanev at autodesk.com
Fri Apr 7 11:20:17 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG191
Type:
Defect
Artifact ID:
MG191 (Layer filter is ignored for DWF-based layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG191 - fix problem with filter parsing as suggested by Walt.
Modified
File: trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp?view=diff&rev=438&p1=trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp&r1=437&p2=trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp&r2=438
File: trunk/MgDev/Common/Stylization/W2DRewriter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/W2DRewriter.cpp?view=diff&rev=438&p1=trunk/MgDev/Common/Stylization/W2DRewriter.cpp&r1=437&p2=trunk/MgDev/Common/Stylization/W2DRewriter.cpp&r2=438
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
