[mapguide][MG198][New] Potential issue with License Management Infrastructure
Ronnie Louie
ronnie.louie at autodesk.com
Fri Apr 7 11:37:18 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG198
Type
Defect
Artifact ID
MG198 (Potential issue with License Management Infrastructure)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Description set to new value
Current licensing infrastructure will attempt to check license for all operations. If license check fails, site and admin operations will also fail. This means that operations such as using the Site Admin to try to view the log files for diagnosing problems will not work.
- Version set to new value
1.0.0
- Steps to Reproduce set to new value
No "real" licensing implementation, but an analysis of the infrastructure reveals that described scenario could potentially occur.
- Resolution set to new value
External
- Summary set to new value
- Component set to new value
Server
- Artifact created
- Defect Severity set to new value
High
- Priority set to new value
P2
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
