[mapguide][MG199][New] Aspect ratio incorrect for symbols in the DWF viewer
Traian Stanev
traian.stanev at autodesk.com
Fri Apr 7 11:51:56 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG199
Type
Defect
Artifact ID
MG199 (Aspect ratio incorrect for symbols in the DWF viewer)
Reported by
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Operating system set to new value
All
- Component set to new value
Server
- Artifact created
- Steps to Reproduce set to new value
Set up a symbol with a width based on an expression and with constant height. In the DWF Viewer notice that the symbols draw as squares with width equal to the height.
- Platform set to new value
All
- Priority set to new value
P2
- Target milestone set to new value
1.0.1
- Version set to new value
1.0.0
- Defect Severity set to new value
Medium
- Subcomponent set to new value
Mapping Service
- Summary set to new value
- Description set to new value
The aspect ratio of some point symbols was wrong in the DWF viewer -- the symbols were always fitting in a square of the size of the bigger dimension (width or height).
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
