[mapguide-issues] ODBC Geometry Question
Berdel, Brian
brian.berdel at mcmtrans.com
Thu Apr 13 16:11:24 EDT 2006
Does this version only support point geometry for ODBC? After loading
polygon data when I create a new layer from that data it acts like it is
point data. Also in the help for connecting to an ODBC Database it
says"
"For Specify Geometry Property, specify the columns that locate the
point: either Lat/Long or X/Y."
-----Original Message-----
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, April 13, 2006 3:48 PM
To: Walt Welton-Lair; Traian Stanev
Cc: Chris Claydon; issues at mapguide.osgeo.org
Subject: [mapguide-issues] [mapguide][MG215][Modified] WMS feature info
support requires new backend query API
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG215
Type:
Enhancement
Artifact ID:
MG215 (WMS feature info support requires new backend query API)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG215: WMS feature info support requires new backend query API
Modified
File: trunk/MgDev/Common/Service/Services/ProxyRenderingService.cpp
https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Ser
vice/Services/ProxyRenderingService.cpp?view=diff&rev=482&p1=trunk/MgDev
/Common/Service/Services/ProxyRenderingService.cpp&r1=481&p2=trunk/MgDev
/Common/Service/Services/ProxyRenderingService.cpp&r2=482
File: trunk/MgDev/Common/Service/Services/ProxyRenderingService.h
vice/Services/ProxyRenderingService.h?view=diff&rev=482&p1=trunk/MgDev/C
ommon/Service/Services/ProxyRenderingService.h&r1=481&p2=trunk/MgDev/Com
mon/Service/Services/ProxyRenderingService.h&r2=482
File: trunk/MgDev/Common/Service/Services/RenderingDefs.h
vice/Services/RenderingDefs.h?view=diff&rev=482&p1=trunk/MgDev/Common/Se
rvice/Services/RenderingDefs.h&r1=481&p2=trunk/MgDev/Common/Service/Serv
ices/RenderingDefs.h&r2=482
File: trunk/MgDev/Common/Service/Services/RenderingService.h
vice/Services/RenderingService.h?view=diff&rev=482&p1=trunk/MgDev/Common
/Service/Services/RenderingService.h&r1=481&p2=trunk/MgDev/Common/Servic
e/Services/RenderingService.h&r2=482
This message was automatically generated by Project Tracker.
To unsubscribe, e-mail: issues-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: issues-help at mapguide.osgeo.org
More information about the Mapguide_issues
