[mapguide][MG216][New] Updated comments in header files.
Philip Sharman
philip.sharman at autodesk.com
Thu Apr 13 17:52:08 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG216
Type
Task
Artifact ID
MG216 (Updated comments in header files.)
Reported by
Philip Sharman
philipsharman (philip.sharman at autodesk.com)
New artifact details:
- Priority set to new value
P5
- Artifact created
- Documentation Notes set to new value
The files affected are:
\MgDev\Common\Service\MapLayer\ChangeList.h
\MgDev\Common\Service\Services\Command.h
\MgDev\Common\Service\System\Configuration.h
\MgDev\Common\Service\System\ConfigurationHeap.h
\MgDev\Common\Service\System\ConfigurationSection.h
\MgDev\Common\Service\Data\ConfigurationSectionCollection.h
\MgDev\Common\Service\System\Disposable.h
\MgDev\Common\Service\Geometry\GeosUtil.h
\MgDev\Common\Service\System\GuardDisposable.h
\MgDev\Common\Service\Util\IpUtil.h
\MgDev\Common\Service\Geometry\Parse\ParseAwktUtil.h
\MgDev\Common\Service\System\Stream.h
\MgDev\Common\Service\System\StreamWriter.h
\MgDev\Common\Service\Util\XmlUtil.h
\MgDev\Common\Service\Data\DisposableCollection.h
\MgDev\Common\Service\Data\NamedCollection.h
\MgDev\Common\Service\Data\SerializableCollection.h
\MgDev\Common\Service\Data\StringPropertyCollection.h
\MgDev\Common\Service\Geometry\AgfStream.h
\MgDev\Common\Service\Geometry\CloseInstruction.h
\MgDev\Common\Service\Geometry\GeometricEntityType.h
\MgDev\Common\Service\Geometry\GeometricPathInstruction.h
\MgDev\Common\Service\Geometry\GeometricPathInstructionType.h
\MgDev\Common\Service\Geometry\GeometricPathIterator.h
\MgDev\Common\Service\Geometry\GeometryComponentCollection.h
\MgDev\Common\Service\Geometry\GeometryUtil.h
\MgDev\Common\Service\Geometry\LineToInstruction.h
\MgDev\Common\Service\Geometry\MoveToInstruction.h
\MgDev\Common\Service\Geometry\QuadToInstruction.h
\MgDev\Common\Service\MapLayer\ObjectChange.h
\MgDev\Common\Service\Services\ConnectionProperties.h
\MgDev\Common\Service\Services\CustomLogoInfo.h
\MgDev\Common\Service\Services\CustomTextInfo.h
\MgDev\Common\Service\Services\FeatureSet.h
\MgDev\Common\Service\Services\LongTransactionData.h
\MgDev\Common\Service\Services\PackageStatusInformation.h
\MgDev\Common\Service\Services\ProxyFeatureReader.h
\MgDev\Common\Service\Services\ProxyFeatureService.h
\MgDev\Common\Service\Services\ProxyGwsFeatureReader.h
\MgDev\Common\Service\Services\ProxySqlDataReader.h
\MgDev\Common\Service\Services\ServerAdmin.h
\MgDev\Common\Service\Services\ServerConnectionPool.h
\MgDev\Common\Service\Services\ServerInformation.h
\MgDev\Common\Service\Services\ServiceFactory.h
\MgDev\Common\Service\Services\SpatialContextData.h
\MgDev\Common\Service\System\NamedSerializable.h
\MgDev\Common\Service\System\Object.h
\MgDev\Common\Service\System\Resources.h
\MgDev\Common\Service\System\Serializable.h
\MgDev\Common\Service\System\StreamHeader.h
\MgDev\Common\Service\Util\LinuxMemoryStatus.h
\MgDev\Common\Service\Util\XmlDefs.h
\MgDev\Common\Service\Geometry\Parse\StringUtility.h
\MgDev\Common\Service\Services\FeatureDefs.h
\MgDev\Common\Service\Net\IOperationHandler.h
\MgDev\Common\Service\Net\BasicPacket.h
\MgDev\Common\Service\Exception\ConfigurationLoadFailedException.h
\MgDev\Common\Service\Exception\ConfigurationSaveFailedException.h
\MgDev\Common\Service\Controller\Controller.h
\MgDev\Common\Service\Net\ControlPacket.h
\MgDev\Common\Service\Geometry\Spatial\MathUtility.h
\MgDev\Common\Service\Net\MemoryStreamHelper.h
\MgDev\Common\Service\Net\Net.h
\MgDev\Common\Service\Net\OperationPacket.h
\MgDev\Common\Service\Net\OperationResponsePacket.h
\MgDev\Common\Service\Net\PacketParser.h
\MgDev\Common\Service\Exception\ParameterNotFoundException.h
\MgDev\Common\Service\Geometry\Parse\ParseAwkt.h
\MgDev\Common\Service\Net\StreamData.h
\MgDev\Common\Service\Net\StreamHelper.h
\MgDev\Common\Service\Net\StreamParser.h
\MgDev\Common\Service\Geometry\Spatial\SpatialUtilityCircularArc.h
\MgDev\Common\Service\Geometry\Spatial\SpatialUtilityVectorAngle.h
\MgDev\Common\Service\Services\ProxyDrawingService.h
\MgDev\Common\Service\Services\ProxyMappingService.h
\MgDev\Common\Service\Services\ProxyRenderingService.h
\MgDev\Common\Service\Services\ProxyResourceService.h
\MgDev\Common\Service\Services\ProxyTileService.h
- Target milestone set to new value
M2
- Resolution Description set to new value
[How do I mark this as "fixed"?]
- Description set to new value
Removed a number of files from the Web API Reference, since they are for internal use only.
This only affects the documenation.
Checked that WebTier.sln still builds correctly.
- Summary set to new value
- Submission Reviewed set to new value
No
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
