[mapguide][MG250][New] WebExtentions unit tests are failing. WFS GetFeature is test...
Konstantin Nikolov
konstantin.nikolov at autodesk.com
Fri Apr 21 18:17:29 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG250
Type
Defect
Artifact ID
MG250 (WebExtentions unit tests are failing. WFS GetFeature is tested only with HTTP GET requests.)
Reported by
Konstantin Nikolov
konstantinnikolov (konstantin.nikolov at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
Run WebExtensions unit tests.
- Artifact created
- Summary set to new value
- Priority set to new value
P3
- Artifact Status set to new value
New
- Resolution Description set to new value
Updated baseline for ServerAdmin unit tests.
WFS GetFeature Tests: Modified the code base so that the current set of parameters is used to form both GET and POST requests.
Tests failed/run: 0/934.
- Version set to new value
1.0.0
- Submission Reviewed set to new value
No
- Description set to new value
WebExtensions unit tests are failing due to an old baseline.
WFS GetFeature supports both GET and POST HTTP requests. Current tests only exercise the operation through HTTP GET.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
