[mapguide][MG250][User] WebExtentions unit tests are failing. WFS GetFeature is test...
Konstantin Nikolov
konstantin.nikolov at autodesk.com
Fri Apr 21 18:24:57 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG250
Type:
Defect
Artifact ID:
MG250 (WebExtentions unit tests are failing. WFS GetFeature is tested only with HTTP GET requests.)
Modified by:
Konstantin Nikolov
konstantinnikolov (konstantin.nikolov at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Assigned to:
konstantinnikolov
-- New value added to attribute Verifier:
konstantinnikolov
-- New value added to attribute Reviewer:
thomastuerke
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
