[mapguide][MG191][Modified] Layer filter is ignored for DWF-based layers
Traian Stanev
traian.stanev at autodesk.com
Wed Apr 26 12:11:27 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG191
Type:
Defect
Artifact ID:
MG191 (Layer filter is ignored for DWF-based layers)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG191 : Further fix for this. In W2D layers are not always referred to by name. Sometimes just an integer ID is used and we need to keep track of the mapping from layer name to ID in order for the W2D layer filter to work correctly.
Modified
File: trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp?view=diff&rev=571&p1=trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp&r1=570&p2=trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp&r2=571
File: trunk/MgDev/Common/Stylization/W2DRewriter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/W2DRewriter.cpp?view=diff&rev=571&p1=trunk/MgDev/Common/Stylization/W2DRewriter.cpp&r1=570&p2=trunk/MgDev/Common/Stylization/W2DRewriter.cpp&r2=571
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
