[mapguide][MG257][New] Update mgserver.sh script to append FDO path to existing LD_...
Bruce Dechant bruce.dechant at autodesk.com
Wed Apr 26 12:22:57 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG257
Type
 Defect
Artifact ID
 MG257 (Update mgserver.sh script to append FDO path to existing LD_LIBRARY_PATH)
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Artifact created
- Defect Severity set to new value
  Medium
- Operating system set to new value
  Linux
- Description set to new value
  The mgserver.sh script overwrites the existing contents of the LD_LIBRARY_PATH with the FDO path.
Instead it needs to append the FDO path to the LD_LIBRARY_PATH.
- Subcomponent set to new value
  Core
- Steps to Reproduce set to new value
  Examine the mgserver.sh script and you will see that the LD_LIBRARY_PATH is overwritten.
- Version set to new value
  1.0.0
- Summary set to new value
- Artifact Status set to new value
  New
- Priority set to new value
  P3
- Target milestone set to new value
  1.0.1
- Component set to new value
  Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
