[mapguide][MG349][New] AJAX Viewer does not display multi-line labels
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Aug 8 19:15:39 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG349
Type
Defect
Artifact ID
MG349 (AJAX Viewer does not display multi-line labels)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Component set to new value
Server
- Description set to new value
Multi-line labels do not display correctly with the AJAX Viewer. The "\n" sequence is not interpreted.
- Subcomponent set to new value
Core
- Operating system set to new value
All
- Platform set to new value
All
- Artifact created
- Summary set to new value
- Version set to new value
1.0.1
- Artifact Status set to new value
New
- Defect Severity set to new value
High
- Steps to Reproduce set to new value
Open a layer and edit the label to be a constant multi-line string, e.g. "Line 1\nLine 2".
The multi-line label displays correctly with the DWF Viewer but not with the AJAX Viewer.
- Priority set to new value
P2
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
