[mapguide][MG349][Modified] AJAX Viewer does not display multi-line labels
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Aug 8 19:19:09 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG349
Type:
Defect
Artifact ID:
MG349 (AJAX Viewer does not display multi-line labels)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
Open a layer and edit the label to be a constant multi-line string, e.g. "Line 1\nLine 2".
The multi-line label displays correctly with the DWF Viewer but not with the AJAX Viewer.
New value:
In the case of DWF output, there is server-side code in DWFRenderer::ProcessMultilineText which splits the label up into multiple pieces. We need similar code for the AJAX Viewer code path.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
