[mapguide][MG349][Modified] AJAX Viewer does not display multi-line labels
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Aug 8 19:21:00 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG349
Type:
Defect
Artifact ID:
MG349 (AJAX Viewer does not display multi-line labels)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
Open a layer and edit the label to be a constant multi-line string, e.g. "Line 1\nLine 2".
The multi-line label displays correctly with the DWF Viewer but not with the AJAX Viewer.
In the case of DWF output, there is server-side code in DWFRenderer::ProcessMultilineText which splits the label up into multiple pieces.  We need similar code for the AJAX Viewer code path.
New value:
Open a layer and edit the label text to be a constant multi-line string, e.g. "Line 1\nLine 2".
The multi-line labels display correctly with the DWF Viewer but not with the AJAX Viewer.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
