[mapguide][MG13][New] AJAX viewer uses wrong layer list after turning on/off layer...
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 14:39:07 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG13
Type
 OS:Issue
Artifact ID
 MG13 (AJAX viewer uses wrong layer list after turning on/off layers)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Component set to new value
  Viewer
- OS:Summary set to new value
- OS:Status set to new value
  New
- OS:Subcomponent set to new value
  Viewer AJAX
- OS:Type set to new value
  Defect
- OS:Priority set to new value
  P2
- OS:Steps to Reproduce set to new value
  Open a web layout and run an HTTP sniffer such as Fiddler. Turn off a layer that was visible and click on the map in select mode. Observe that the LAYERNAMES parameter still contain the name of the layer that was turned off.
- Artifact created
- OS:Description set to new value
  The list of layers that the AJAX viewer sends to the server for selection operations is not refreshed when a layer is turned on or off.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
