[mapguide][MG13][User] AJAX viewer uses wrong layer list after turning on/off layer...
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 14:39:24 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG13
Type:
OS:Issue
Artifact ID:
MG13 (AJAX viewer uses wrong layer list after turning on/off layers)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute OS:Assigned To:
alainlebatard
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
