[mapguide][MG12][Modified] Specifying a center/scale in a web layout may cause the map ...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Feb 24 17:00:53 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG12
Type:
OS:Issue
Artifact ID:
MG12 (Specifying a center/scale in a web layout may cause the map not to show)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- OS:Resolution Description set to new value:
The reason for the bug was that the formatting of the numbers representing the scale and the center was done according to the locale. For numbers greater or equal to 1000, the formatting number included ',' characteres. for example the scale as specified in the step to reproduce was formatted as 23,123.00. This extra commas were causing problem when generated in a parameter list, which is comma separated.
The fix was to make a locale-independant formatting, so no extra characters get added to the string representation of the number
-- OS:Status changed:
Old value:
New
New value:
Resolved
-- OS:Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
