[mapguide][MG12][User] Specifying a center/scale in a web layout may cause the map ...
Alain Lebatard alain.lebatard at autodesk.com
Fri Feb 24 17:02:25 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG12
Type:
OS:Issue
Artifact ID:
MG12 (Specifying a center/scale in a web layout may cause the map not to show)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute OS:Reviewer:
trevorwekel
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
