[mapguide][MG14][Modified] Updating OGC Templates to reflect new Studio support for met...
Thomas M. Tuerke thomas.m.tuerke at autodesk.com
Mon Feb 27 17:04:58 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG14
Type:
OS:Issue
Artifact ID:
MG14 (Updating OGC Templates to reflect new Studio support for metadata)
Modified by:
Thomas M. Tuerke
thomastuerke (thomas.m.tuerke at autodesk.com)
The following modifications were made to this artifact:
-- OS:Developer Notes set to new value:
MgDev/Server/src/Wms/
1.0.0.xml.awd
 - Modified the Layer.xml definition to leverage the metadata exposed by
   Studio.
1.1.0.xml.awd
   Studio.
1.1.1.xml.awd
   Studio.
OgcWmsService.config.awd
 - Provide default definitions for key metadata elements, since Studio does
   not provide any user-input validation.
MgDev/Web/src/HttpHandler/
HttpWmsGetCapabilities.cpp
 - Removed the "general" flag, since the position of the data it returns has
   changed and interferes with the parsing of metadata.
OgcWmsServer.cpp
 - Modified the enumeration logic to traverse only the layers with the
   "IsPublished" definition set.
WmsLayerDefinitions.cpp
 - Tweaked the creation of metadata definitions to ensure that system-defined
   and nascent user-defined metadata stay in separate namespaces.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
