[mapguide][MG28][New] Search UI display internal command name instead of display n...
Alain Lebatard
alain.lebatard at autodesk.com
Mon Feb 27 18:04:01 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG28
Type
OS:Issue
Artifact ID
MG28 (Search UI display internal command name instead of display name)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- OS:Description set to new value
The search UI displays the internal name of the search command, which should not appear in the UI. The display name should appear instead.
- OS:Priority set to new value
P2
- OS:Subcomponent set to new value
Viewer AJAX
- Artifact created
- OS:Status set to new value
New
- OS:Component set to new value
Viewer
- OS:Type set to new value
Defect
- OS:Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
