[mapguide][MG28][User] Search UI display internal command name instead of display n...
Alain Lebatard alain.lebatard at autodesk.com
Mon Feb 27 18:04:22 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG28
Type:
OS:Issue
Artifact ID:
MG28 (Search UI display internal command name instead of display name)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute OS:Assigned To:
alainlebatard
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
