[mapguide-issues] [mapguide] Service Does not Start
Berdel, Brian brian.berdel at mcmtrans.com
Thu Jun 1 14:17:43 EDT 2006
Event Type:	Error
Event Source:	Service Control Manager
Event Category:	None
Event ID:	7022
Date:		6/1/2006
Time:		2:06:01 PM
User:		N/A
Computer:	FW0249
Description:
The MapGuide Server service hung on starting.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
-----Original Message-----
From: Ronnie Louie [mailto:ronnie.louie at autodesk.com]
Sent: Thursday, June 01, 2006 1:29 PM
To: Bruce Dechant; Ronnie Louie
Cc: issues at mapguide.osgeo.org
Subject: [mapguide-issues] [mapguide][MG289][Modified] Joins do not work
when join property types are different
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG289
Type:
Defect
Artifact ID:
MG289 (Joins do not work when join property types are different)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Fixed situation where primary data value is string type and represents a
number with decimals.  Previously this was always treated as string
which leads to unsuccessful join because the primary and secondary
values would not be equal.
The fix involves identifying if the primary data value is a number, and
if the secondary data type is also a number, then the
FdoComparisonOperator_EqualsTo is used.
Example:
Previous behavior:
   Primary Value: "'115.0000'" (string)
   Secondary Value: 115 (integer)
   Result: No join occurrs because "'115.000'" not comparable to 115
New behavior
   Primary Value: "'115.0000" (string) becomes 115.0000 (double)
   Result: Join successful because 115.0000 is comparable to 115
This message was automatically generated by Project Tracker.
To unsubscribe, e-mail: issues-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: issues-help at mapguide.osgeo.org
More information about the Mapguide_issues mailing list
