[mapguide][MG304][New] GLOB: Overlapped text in "Create a Buffer" pane
Alain Lebatard alain.lebatard at autodesk.com
Fri Jun 2 13:01:52 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG304
Type
 Defect
Artifact ID
 MG304 (GLOB: Overlapped text in "Create a Buffer" pane)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Priority set to new value
  P2
- Artifact Status set to new value
  New
- Component set to new value
  Web Server Extensions
- Summary set to new value
- Description set to new value
  1. Open IE browser and click on AJAX Viewer link.
2. Click on "Buffer" button in toolbar menu.
3. "Create a buffer" pane appears.
Text 'Transparent' under transparency is truncated.
- Defect Severity set to new value
  Medium
- Platform set to new value
  All
- Version set to new value
  1.0.0
- Artifact created
- Subcomponent set to new value
  Viewer Command
- Steps to Reproduce set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
