[mapguide][MG44][New] Defect 759243 GLOB: Garbled strings when server is down.
Trevor Wekel trevor.wekel at autodesk.com
Wed Mar 1 11:52:40 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG44
Type
 OS:Issue
Artifact ID
 MG44 (Defect 759243 GLOB: Garbled strings when server is down.)
Reported by
 Trevor Wekel
 trevorwekel (trevor.wekel at autodesk.com)
New artifact details:
- OS:Priority set to new value
  P1
- OS:Type set to new value
  Defect
- OS:Operating System set to new value
  All
- OS:Target Milestone set to new value
  1.0.0
- OS:Steps to Reproduce set to new value
  Use a UTF-8 localized resource file and switch the default locale.
- OS:Build set to new value
  160.10
- OS:Version set to new value
  1.0.0
- OS:Summary set to new value
- OS:Keywords set to new value
  UTF-8 resource localization
- OS:Description set to new value
  UTF-8 localized resource files for Server and Web Tier will not load.  The ACE configuration object we are using does not support UTF-8.
- OS:External ID set to new value
  759243
- OS:Status set to new value
  New
- OS:Component set to new value
  WebServerExtensions
- Artifact created
- OS:Platform set to new value
  ALL
- OS:Subcomponent set to new value
  Map Agent
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
