[mapguide][MG44][Modified] Defect 759243 GLOB: Garbled strings when server is down.
Trevor Wekel
trevor.wekel at autodesk.com
Wed Mar 1 12:35:01 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG44
Type:
OS:Issue
Artifact ID:
MG44 (Defect 759243 GLOB: Garbled strings when server is down.)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- OS:Localization Notes set to new value:
Resource files web_??.res and server_??.res should be UTF-8 compliant with this submission.
-- OS:Developer Notes set to new value:
Ripped out the ACE configuration code and replaced it with a simple wstring based parser. New parsing routine is UTF-8 compliant.
Testing
Open source Windows Server
Run: 378 Failures: 1 Errors: 0
1 failure in Feature Services (same as build)
Open source Windows Web Server Extensions
921/921 passed
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
