[mapguide][MG46][New] Add support for Lambert_Conformal_Conic projection (Note: un...
Bruce Dechant
bruce.dechant at autodesk.com
Wed Mar 1 18:55:02 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG46
Type
Enhancement
Artifact ID
MG46 (Add support for Lambert_Conformal_Conic projection (Note: underscores))
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Resolution Description set to new value
Add support for the "Lambert_Conformal_Conic" projection.
- Justification set to new value
All of the Redding data is in the Lambert_Conformal_Conic projection.
- Artifact Status set to new value
New
- Summary set to new value
- Priority set to new value
P2
- Resolution set to new value
Submitted
- Target milestone set to new value
1.0
- Artifact created
- Description set to new value
PROJ4 is very picky about the names of coordinate system elements it supports.
It does support the "Lambert Conformal Conic" projection without the underscores, but does not recognize it with the underscores.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
