[mapguide][MG46][Modified] Add support for Lambert_Conformal_Conic projection (Note: un...
Bruce Dechant bruce.dechant at autodesk.com
Wed Mar 1 18:56:52 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG46
Type:
Enhancement
Artifact ID:
MG46 (Add support for Lambert_Conformal_Conic projection (Note: underscores))
Modified by:
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG46
Modified
File: trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_api.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_api.h?view=diff&rev=149&p1=trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_api.h&r1=148&p2=trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_api.h&r2=149
File: trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_proj4.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_proj4.cpp?view=diff&rev=149&p1=trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_proj4.cpp&r1=148&p2=trunk/MgDev/Oem/gdal-1.3.0/ogr/ogr_srs_proj4.cpp&r2=149
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
