[mapguide][MG49][Modified] ZoomToView in AJAX viewer does not always update a tiled vie...
Alain Lebatard alain.lebatard at autodesk.com
Thu Mar 2 13:43:13 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG49
Type:
Defect
Artifact ID:
MG49 (ZoomToView in AJAX viewer does not always update a tiled view)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The problem was due to the fact that in tile mode, paning requires additional steps to refresh the tiles. The zoomtoview API was not executing these steps.
Before this fix GotoView was the function that performed a change of view with zoom, and MoveView was the function that performed a change of view without zoom (pan only).
With this fix, both functions have merged into a unique GotoView function that takes care of all situations, eliminating the risk that the wrong function is executed, which was the case for ZoomToView.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
