[mapguide][MG50][New] Fix failed ServerAdmin unit tests under Linux
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Mar 2 14:18:09 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG50
Type
Defect
Artifact ID
MG50 (Fix failed ServerAdmin unit tests under Linux)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Summary set to new value
- Version set to new value
1.0.0
- Priority set to new value
P2
- Artifact created
- Target milestone set to new value
1.0.0
- Operating system set to new value
Linux
- Component set to new value
Server
- Platform set to new value
PC
- Artifact Status set to new value
New
- Description set to new value
The ServerAdmin unit test would fail under Linux due to a missing data file (World.mgp).
- Defect Severity set to new value
Medium
- Steps to Reproduce set to new value
Run the ServerAdmin test suite under Linux, and 5 tests will fail due to the missing data file.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
