[mapguide][MG50][Modified] Fix failed ServerAdmin unit tests under Linux
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Mar 2 14:21:07 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG50
Type:
Defect
Artifact ID:
MG50 (Fix failed ServerAdmin unit tests under Linux)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The Makefile which copies the data files to the runtime location was not copying one required file.
-- Status Explanation set to new value:
Code fix has been submitted.
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
