[mapguide][MG50][Modified] Fix failed ServerAdmin unit tests under Linux
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Mar 2 14:54:24 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG50
Type:
Defect
Artifact ID:
MG50 (Fix failed ServerAdmin unit tests under Linux)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The ServerAdmin unit test would fail under Linux due to a missing data file (World.mgp).
New value:
The ServerAdmin unit test suite would have some failures under Linux due to a missing data file (World.mgp).
-- Status Explanation set to new value:
Old value:
Code fix has been submitted.
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
