[mapguide][MG51][New] Web Tier uses incorrect locale.
Steve Dang steve.dang at autodesk.com
Thu Mar 2 14:56:16 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG51
Type
 Defect
Artifact ID
 MG51 (Web Tier uses incorrect locale.)
Reported by
 Steve Dang
 stevedang (steve.dang at autodesk.com)
New artifact details:
- Component set to new value
  Web Server Extensions
- Summary set to new value
- Description set to new value
  Some code in the Web Tier does not use the correct locale. This causes some message fail to load from the resource file when an exception gets thrown.
- Artifact Status set to new value
  New
- Defect Severity set to new value
  High
- Artifact created
- Version set to new value
  0.9.1
- Priority set to new value
  P2
- Steps to Reproduce set to new value
  1. Start the Site Admin app.
2. Try to perform some operation that could results in an exception gets thrown from the Server.
3. Notice that the Site Admin displays a message "Failed to retrieve message for ...".
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
