[mapguide][MG60][New] Linux Install Changes ( Fixes)
Vishal Bangia
vishal.bangia at autodesk.com
Fri Mar 3 14:31:14 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG60
Type
Defect
Artifact ID
MG60 (Linux Install Changes ( Fixes))
Reported by
Vishal Bangia
vishalbangia (vishal.bangia at autodesk.com)
New artifact details:
- Resolution set to new value
Submitted
- Description set to new value
build_oem.sh hardlocks the DWFTK7.1 library to
/usr/local/mapguideopensource
This causes problems in
1) Flexible installs
2) RPM builds
- Target milestone set to new value
1.0.0
- Version set to new value
1.0.0
- Steps to Reproduce set to new value
build_oem.sh
./configure --prefix=$HOME/testMgDev
make install
The DWFTK7.1 libraries are installed in /usr/local/mapguideopensource while the rest of the server binaries are in $HOME/testMgDev
- Resolution Description set to new value
Added --prefix, --help options and the supporting logic to the build_oem.sh script.
- Artifact Status set to new value
New
- Component set to new value
Server
- Status Explanation set to new value
This does not affect the default installation.
However, it would make the install system far more robust.
- Summary set to new value
- Artifact created
- Priority set to new value
P3
- Submission Reviewed set to new value
No
- Platform set to new value
PC
- Operating system set to new value
Linux
- Defect Severity set to new value
Medium
- Subcomponent set to new value
General
- OS Distribution and Version set to new value
Redhat Linux 3.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
