[mapguide][MG59][Modified] configure.in refers to Mentor
Traian Stanev
traian.stanev at autodesk.com
Fri Mar 3 14:31:28 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG59
Type:
Defect
Artifact ID:
MG59 (configure.in refers to Mentor)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Assigned
-- Resolution Description set to new value:
Old value:
References to Mentor removed from configure.in
New value:
and Makefile.am under Server/src/Core
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
