[mapguide][MG68][Modified] Undefined exception raised when doing coordinate system tran...
Walt Welton-Lair walt.welton-lair at autodesk.com
Mon Mar 6 15:15:21 EST 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG68
Type:
Defect
Artifact ID:
MG68 (Undefined exception raised when doing coordinate system transformation)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Old value:
1/ Build a debug version of the server
2/ Extract the attached repository and point the server to it
3/ Run the server interactively in Visual Studio
4/ Open the "Defect 764323" map
5/ Hover somewhere over the top of the map
=> the server breaks with an exception
The exception gets raised in CoordSysTransform.cpp, line 570:
  //if proj failed to convert, generate an exception
  throw;
We simply need to change "throw" to something like:
  throw new CCoordinateSystemTransformFailedException(...);
New value:
5/ Hover somewhere near the northern limit of the map
=> Visual Studio breaks with an exception
  throw;
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
