[mapguide][MG76][Modified] AJAX Viewer status bar shows "(Degree)"
Alain Lebatard
alain.lebatard at autodesk.com
Thu Mar 9 17:35:09 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG76
Type:
Defect
Artifact ID:
MG76 (AJAX Viewer status bar shows "(Degree)")
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
The 'Degree' string displayed in the status bar of the web surround comes from the mapguide API. The web surround uses MgCoordinateSystem::GetUnits() to get the units string.
Because there are many possibilities of units, we cannot process each of them to change it to a more readable form, so we will keep displaying the units as it is encoded in the WKT definition of the coordinate system.
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution set to new value:
Will Not Address
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
