[mapguide][MG88][New] Server uses wrong mime type for DWFs
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Mar 9 17:53:13 EST 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG88
Type
Defect
Artifact ID
MG88 (Server uses wrong mime type for DWFs)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Platform set to new value
All
- Version set to new value
1.0.0
- Operating system set to new value
All
- Steps to Reproduce set to new value
None
- Priority set to new value
P2
- Subcomponent set to new value
Core
- Summary set to new value
- Artifact created
- Description set to new value
The server is setting the mime type for DWFs to "application/x-dwf". It should be "model/vnd.dwf".
- Resolution set to new value
Submitted
- Status Explanation set to new value
Code fix has been submitted to the trunk stream.
- Defect Severity set to new value
High
- Resolution Description set to new value
- Component set to new value
Server
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
